No G8 Female Poses
For G8 female only, no poses, wardrobe, hair, etc shows up in LH pane. The greyed out Midori figure appears as shown in above image for any G8 female selected. For all other generations everything is fine. I just purchased the Midori character and saved a scene with it, but on a seperate drive. I have since uninstalled the character and also created a new work space. No luck.
Try reinstalling the Genesis 8 (Female) Starter Essentials. There seem to be a couple of products that are somehow breaking the compatibility baseness of their base figure
artinstead, you are not logged:
In some rare cases when you restart DS offline the smart content disapears for no reason, login online will get back your products.
other option is uncheck this marker for all your content not be filtered based on your viewport selection.
Exactly. I reinstalled G8F starter essentials, uninstalled Midori (first), all is now fine. Too bad though, I liked that character.
Thank you.
You probably don't need to uninstall Midori. Please refer to the following.
https://www.daz3d.com/forums/discussion/comment/6249576/#Comment_6249576
Thanks. Good info.
I picked up Madori a day or so ago and had the same problem today, though when I accessed Gen 8 SE, it was greyed out in the product list as if it had not been installed at all. I shut Daz down and opened DazCentral and Gen8 SE was not in my asset list. I reopened Daz, uninstalled, restarted, reinstalled from Connect, then the problem went away.
Also, thanks for the fix!
