Conversion help?
I was attempting to convert the Sheer Greatness leggings for Genesis to a Genesis 8 figure, and a few things happened. For starters, when I loaded the leggings and clicked on the stirrup option, what you see in the image happened, where they had taken on a torn look. I also tried simply converting them to a G8 body using a script converter, but the converter said that it couldn't find any clothing, even when I clicked on the file itself directly. Any help, please?
Try using my auto-fit clones for clothing with pant legs or long sleeves, esp. on figures changing poses T <=> A.
Please use Smooth Shaded drawstyle for the Viewport if you are going to take a scfreenshot of a nude figure.
If you select the leggins in the Scene pane and then in Parameters under Constraints click the Fit To button, then select Genesis 8 Female you should get the AutoFit dialogue - select Genesis as the figure the item was made for and it will convert. I assume the lack of automatic fitting is the reason the converter fails to see the clothing.
I don't see a stirrup option - is that in the expansion?
Ah, I see. Okay then.
Yes it is. My apologies for not clarifying that.
