dForce ChicXlook Outfit crashes on simulation?
So this fun set:
https://www.daz3d.com/dforce-chicxlook-outfit-for-genesis-8-females
Is on sale, and I figured, why not?
Well, every time I try to simulate dynamics on the outfit, Studio crashes.
I can simulate other clothing items just fine - the MBS skirt, for instance - and they simulate, stabilize, and work as expected.
The pants or top from ChicXlook, however, run through their Springs to a certain point and then I start getting errors like this:
2020-11-24 22:17:55.591 Spring(12860, 13500) of node "ChicXlook_Pants" extended: rest length < collsion offset (0.190291 < 0.20001)
2020-11-24 22:17:55.597 Shortest spring had length: 0.0288815
2020-11-24 22:18:11.122 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: HTTP/1.1 400 Bad Request
Needless to say, I have absolutely no idea why cloud task notifier would start trying to make HTTP requests, but I get several hundred of these, and then Studio crashes out.
I don't see any particularly telling errors in the log to tell me what the shutdown is. I have sent the crash logs to Apple via the crash reporter, so there's a chance someone at Daz will get a notification on that.
Restarting the application results in a clean restart per the log.
I'm using 4.14.0.8 on Mac OS 10.15.7 if it matters.
Thoughts?
This is an error that's popped up occasionally.
https://www.daz3d.com/forums/discussion/415346/got-an-unknown-command-from-the-persistent-connection
Thanks, I've tacked a comment on to that thread.
As I said there, I can't for the life of me figure out why a bad http call cause a dforce simulation to crash, but here we are.
I tested with a variety of other dforce items last night. It's just the ChicXlook outfit. Which kind of sucks, because I really like the trousers and hat that come with that set. They go well with the character I'm using them on.
