Does DAZ support 3rd decimal?
When I type 0.187 and press Enter,it just become 0.19
So does DAZ support 3rd decimal?
If yes,how can I do that?
If no,will be supported in the future version?
I really need 3rd decimal
Thanks.
Post edited by zdsmdbh_033715b24d on
You can post Images here with the Choose File option under the Text Field. And you can edit the parameters to use them if you wish. Use the Gear Icon and then adjust the Nudge.
Thanks!
But I am not sure how to use the Nudge.
I try to type 10000 100 1 0.1 0.001 0.00001
But seems it doesn't make any diffrent.
And I noticed that Value is 0.187,Main Panel display as 0.19.
So it's actually 0.187,but just display as 0.19 in Main Panel?
If so,is there anyway display as 0.187 in Main Panel?
I'm not sure it can be done for a Parameter that is already set to a Max that is a percentage. Sorry but I did try.
Nudge defines how much the slider increases and decreases when you drag the handle in the parameters bar. A higher number moves the slider in larger amounts, while lower numbers give you a much smoother slider. This is most useful on things you want more fine control for.
As for the truncating issue, I wouldn't worry too much about it. It still stores the right value internally, so should still give the proper effect. With morphs, such small percentages generally don't have much impact anyway.
