how do open up the nostrils
2»
  • SpyroRueSpyroRue Posts: 5,020
    Oops, Miss-understood the query then. I read it as though the OP was dialing a character with purchased morphs, and that something went wrong with an unknown morph. The early posts confused me :red:
  • JaderailJaderail Posts: 0
    Actually people the base is the round disk and will show the starting position of the Zero mesh until the Deformer the Spindle top like thing is moved away from the base. The base controls the strength and to some extent the direction of morph as the mesh is Deformed, you pull the Deformer to raise mesh toward the base or push toward the base with the Deformer to dimple a mesh. The base with the Deformer spindle at zero to it does not influence the mesh so the base is a controller and the deformer the worker.
    646 x 589 - 116K
  • NovicaNovica Posts: 23,924
    When you move the base out, does it influence the field, or does only the d-former do that? In other words, if I have the base out further from the nose, does that mean there will be more pull on the field when the slider is used, or is it totally dependent on where the d-former is?
    OR, is it dependent on how far apart the base and d-former are?
    edited June 2014
    Only the Deformer effects the Field, that is how I can move the Base any place I wish it and use it to line up how the Deformer will Pull or Push the mesh. The base has zero influence on the Field or mesh.
    EDIT: The Deformer and distance from the Base is the strength of the amount the mesh will change. So it is Deformer from Base that matters. But of course Angle and other factors can be controlled by were the Base is at at the time the Deformer is moved.
    Post edited by Jaderail on
  • blue6stringblue6string Posts: 60
    I just want to thank everyone, especially --- Novica Jaderail
    Everything is rolling smoothly and now i have a very useful tool (deformers) in my toolbox
    Thanks so much!!
    Glad to help :) Have fun!
    And thank you Jaderail for clarifying.
