Genesis 8 Female loads with my morph
Angells
I did it again but I dont know how, as I thought I had it at zero when I saved my morph. I can't even fix it now. My genesis 8 female just loads with my morph. I fixed it once but I don't know what channel and value to zero out now.
To fix any ill-behaving morphs, do as follows;
1. Load your base figure or the developer version to an empty scene. ("Genesis 8 Basic Female" or "Genesis 8 Female Dev Load")
2. Select the figure
3. Select "Show Hidden properties" in the Parameters-Tab, drop down menu (right-click)
4. Zero the figure (Found in Parameters-Tab, drop down menu)
5. Memorize the figure (Found in Parameters-Tab, drop down menu)
6. File->Save As->Support Asset->Save Modified Assets
This procedure will zero the default value in the ill-behaving morph/morphs, and while saving DS also shows you a list of the morphs it is changing.
I can't find the show hidden properties or zero the figure in daz studio 4.15 as I did it again. Help where are they
Ok I did find it and I did what you said and loaded a new character thank you.
