Surface Parameters only showing the the lowest level
GranvilleGranville Posts: 698
edited November 2020 in Daz Studio Discussion
Daz 4.14.0.8 here (lovin' it mostly)
Problem
The parameters for surfaces are only showing up at the lowest level. In other words Surface->Base->Diffuse show nothing. But Surface->Base->Diffuse->Reflection shows...
  • Metallicity
  • Base Color
  • Diffuse Roughness
Previous Versions
In the prior version of Daz Studio it would show all the cascading parameters underneath a settting. This let you group them anyway you wanted. You could also edit multiple surfaces at the same time.
As usual, I'm sure I messed something up. Can anyone tell me what to do?
Post edited by Granville on
  • There should be a Show Sub-Items check box below the list - turn that on and it will not be restricted to the current level.
  • Thanks, Richard. As always you are sooooo. Helpful.
