[SOLVED] No iray preview in viewport after 4.14 General Release
StratDragonStratDragon Posts: 3,278
edited November 2020 in Daz Studio Discussion
SOLVED
After downgrading the driver for the GPU (256.71), then reinstalling the drivers (457.30), creating new scenes instead of loading previous ones; all which failed I added a primitive and the viewport rendered it.Once I deleted the primitive the scene remained functional in the Iray viewport. I tried to report in the bug submission but it repeatedly fails.
On a related note I have moved to an area where broadband is not available and I'm continuously throttled by the sole service prodvider in the area down dial-up speed so downloading can take substantial time.
Original Post:
After upgrading to 4.14.0.8 I can no longer see a preview of my scene when switching to NVIIDA Iray in the veiwport
I keep getting logged out when I try to edit my sig buy specs are
Windows 10, 64GB RAM, 2x3.06GHz 6 Core Xeon CPU(s), MSI Nvidia 1660Ti 6GB DDR6. NVIDIA Driver 457.30
steps:
load figure
select NVIDIA Iray from the dropdown
Expected result
Iray preview of rendering
Actual result:
gray, textureless scene
Steps taken:
reset Iray engine to default from Render Setting Pane
rebooted.
result:
no change, still doesn't work.
what am I doing wrong? what do I need to do to make this work again?
Post edited by StratDragon on
