re-install question - which CMS thing?
DiomedeDiomede Posts: 15,401
edited November 2020 in Carrara Discussion
did a fresh install
should I install the postgre database for CMS?
pros and cons?
Post edited by Diomede on
  • you don't need any with valentina in them as it is now obselete
    (unless you are running D|S4.6 or something)
  • DiomedeDiomede Posts: 15,401
    thank you
  • DartanbeckDartanbeck Posts: 21,988
    Also, I believe that any of the highlighted Builds (in yellow) are for beta builds. "Public" = Public Beta, so you're not installing the officil release in those situations. To keep things more clear, deselect the various beta build options from view in DIM
    yes
     with all the autofits and crossfits,
    outfits are pretty much interchangeable, kinda makes cms moot point
    and the meta data would need to be meticulous.
