(solved) mc6 and pz, ,, which is better for daz studio 4.6?
kitakoredaz
Hi I just need mat preset files for daz studio 4.6 ,not poser user.
but in my content library of daz studio, there are many product,
(for V4) which have two type files for same material. usually mc6 and pz.
I do not plan to un-install them, but In smart content, I may only need one of them.
then in short , mc6 and pz,, which is better for ds 4.6? :roll:
Post edited by kitakoredaz on
I'd probably use the pz2 for DS. The mat will still need tweaking either way though.
If the File has a Scroll on it it has a Bootstrap that loads a DAZ Studio version, often that is a tweeked Pz2 file. So check the code and be sure.
Thank you both,, :)yes, PZ2 seems have a little square mark,,and I can find ds script files,
in same directory ,, then it auto-adjust mat for daz studio?
(may not need many tweaking as defaut?)
Then,, I may only need to use PZ2 (usualy in pose section,,in poser format)?
I had not thought,, mc6 and pz2 actually set different mat in daz studio ^^;
seldom use these type mat files,,
but today I check them,,it seems slightly different,,
it means,, ds auto adjust mat for some PZ2(with ds scripts) , but not adjust mat for mc6?
but I know some product, mc6 with dsa,,, @@;
about this case,, I need to use the mc6 @@;?
The Scroll means it will auto load the proper file for you. In DS it loads the DS material settings and in Poser it just defaults to the poser version. That is why the bootstrap is there.
thank you, so as to say I may use only pz file with scroll ,
when there are both pz2 and mc6.
You can still use Poser mats, you just have to be aware of what to change. I saved this post from adamr001 on adjusting Poser mats for use in DS from the old forums before they were taken offline:
><; My mistake,, I may use only >>> I prefer to use only
thank you vascania,, I know we can use mc6 too,, ^^;
then usually need to adjust them for daz studio if there is no scroll (ds script files to auto load setting)
as Adam001 discribed.
