Not your average Filament thread
I've followed the tutorial, did a clean driver install for my GPU, double checked that Windows and my other drivers were up to date, uninstalled and reinstalled DAZ, unplugged it and plugged it back in, and then some. Filament won't display at all. Viewport appears empty. I created nodes and added distant and spotlights. So far, I haven't been able to find any other post regarding my situation. Any constructive advice is most appreciated. Please don't give me a stock answer. I've already tried the basics. Thank you.
Whata re your system specs? Could you upload the scene file so others can have a look at it? That message looks like an OpenGL render warning.
Here's what I have
Put some clothes on the character, switched to Filament and got this.
I went ahead and tried that, and it makes no change.
In my new in
stall of 4.14 the filiment (PBR) is grayed out. Does nothing?
I get the pop-up if I render (but it still renders to a new window, and still previews). I suspect it's a bug, acting as if it is going to do an OpenGL render, so it's probably worth reporting.
