[Solved] Octane Render and Nvidia 3000 Series (Ampere)
Hello everyone,
I just wanted to know if Octane Render Free plugin for Daz Studio was supporting the latest Nvidia GPU ? I have a RTX 3090 and I can't use Octane Render, when i'm going into "Viewport" it will load infinitely.
I also noticed that when going into "device settings" I will only have the possibilite to use RTX 3090 for the denoiser. Is that normal ?
Edit : I was using an old version of the plugin ! Downloaded the latest here : https://render.otoy.com/forum/viewtopic.php?f=44&t=73445 and it now supports the RTX 3090.
Post edited by sylviasobaka on
I too am having the same problem. New RTX-3090, "denoiser" only and endless Viewport load.
Hopefully, someone will be able to help.
My apologies, I didn't notice the new download link.
Thanks.
Hi again Sylvia,
I just downloaded the update for the Addin (2020_1_4_55 PRIME), installed and restarted my system and I still have the endless "Building Geometry" in the Viewport window.
Any guidance? Have I missed something?
Thanks, I was having the same problem with my 3090 card as well and reloaded Oactane again with the updated link. Now the viewport is working!
However, now I have no access to the denoiser. I don't understand why I gained everything else, but lost that now. Should I have completely uninstalled Octane before running the latest installer? How would I do a complete uninstall of Octane?
Thanks.
Octaine Render. Open SYSTEM tab. Open DEVICE SETTINGS. Make sure your NVIDIA card is checked for TONEMAP & RENDER.
