OctaneRender viewport overrides Daz Render settings
denisnormandin
When I start the OctaneRender viewer, Daz render settings are reset to match the default Octane viewport ratio, 1.18227 : 1.
Then, changing them back to my desired values has no effect on either viewports. Note that the Octane viewport setting are set to the same values as those in the Daz menu.
See the joined pictures for more clarity.
Now is the time when I feel a bit silly!
There is an icon on the Octane viewport that toggles between the the two render size configurations.
There is no bug at all !
It affects both viewports.
