The Wrong Place, Wrong Time Complaint Thread
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Question for those in the know: For some reason, several of my outfits, including the Nano Suit Sam is wearing, keeps coming up with duplicate files. How do I resolve this ( as I don't have an uninstall files for most things)?
Fur coats :lol: Not so much cold as featureless fog for half a day and no sun for the rest makes for a dull 'borg :lol:
featureless fog remedy. something warm with mulling spices :) hot apple pie?
in ds?
need jaderail.
sleepy time zZZ
in ds?
need jaderail.
Yeah, in DS 4.5
I'm pretty sure I have to remove all of the files and redownload the product, but I'm not sure what folders I should look in to make sure I have everything.
Yeah, in DS 4.5
Are you using the DIM?
It's DS 4.5? I read something last night about this happening but it was after someone installed the newest release of 4.6. I believe it was fixmypcmike that answered to do a search of known runtimes (in the menu somewhere) and that would eliminate the duplicate references. But I don't know if that applies to your problem. You could try it, though. I don't think it will hurt anything, it just might not fix it either.
I think that was in the Nuts 'n Bolts forum, but I'm not sure.
Dana
Yeah, in DS 4.5
Dana
Do you mean duplicate formulas, or duplicate icons in Smart Content/Categories?
Essentially, my runtime is very, very old and was pulled from one PC to my new PC. Somewhere along the way, some files somehow duplicated, I guess. It's not just the Nano Suit. A few others also have the duplicated files alert. I haven't switched to DIM, as I've been on a hiatus for quite some time. I'm not entirely sure where to start on that.
Dana
When I load them into the scene, I get a pop that says there are duplicated files in the log. I know the Nano Suit for Genesis is one. The Hunter for M4 also apparently has duplicated files. I'm not even entirely sure just how many items have this problem.
Correction: I apparently am on 4.6 - once this render finishes, I'll try to get the exact version number.
Dana
Do you have multiple content folders?
Just one. One really big folder. It's really old (from 2006) and like I said, I copied a backup copy from my old PC to the new old. I can't remember if I had this problem on the old system. It's been a year and a half since I turned that computer on (not sure if it even works as it was on its dying).
If if makes any difference, I'm using Daz 4.6.2.118.
NM
Darn it, I'm hitting the wrong buttons tonight. Sorry for the spam.
Can you post one of the error messages from the log?
[duplicate post]
Duplicate id "Namo-Suit-HR" found in file "/data/Midnight_stories/Nano-Suit/Nano-Suit-HR/Namo-Suit-HR.dsf"
WARNING: fileinput\dzassetdaz.cpp(5398): Unsupported formula: /data/Midnight_stories/Nano-Suit/Nano-Suit-HR/Namo-Suit-HR.dsf#Namo-Suit-HR
WARNING: fileinput\dzassetdaz.cpp(5217): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/general in file : /data/Midnight_stories/Nano-Suit/Nano-Suit-HR/Namo-Suit-HR.dsf#Namo-Suit-HR
WARNING: fileinput\dzassetdaz.cpp(5217): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/x in file : /data/Midnight_stories/Nano-Suit/Nano-Suit-HR/Namo-Suit-HR.dsf#Namo-Suit-HR
WARNING: fileinput\dzassetdaz.cpp(5217): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/y in file : /data/Midnight_stories/Nano-Suit/Nano-Suit-HR/Namo-Suit-HR.dsf#Namo-Suit-HR
WARNING: fileinput\dzassetdaz.cpp(5217): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/z in file : /data/Midnight_stories/Nano-Suit/Nano-Suit-HR/Namo-Suit-HR.dsf#Namo-Suit-HR
File loaded in 0 min 9.4 sec.
Loaded file: Nano-Suit-HR.dsf
You could try downloading the current version and installing over your existing version -- that should handle the Duplicate ID issue, and there's a good chance it would fix the others also.
Go to Content DB Maintenance menu, mini menu on cormer of Content Library Tab is fast way there. Once open do a Remove Un-mapped Base paths and Orphans and then Remove Orphaned File References.
If that does not work Do Export User Data then Reset the Database and then Re-Import Metadata.
what do you do to stop yourself from doing something you know you shouldn't do?
willpower usually works, but sometimes... and what do you do then?
like buying content when the rent is due ?
iz a ugh grey day
doh, got 11 minutes to be out the door. it's really a stay home kinda day, but i cannae afford it :shut:
aches & pains = low? are we living in the same continuum? yowch
Or buying content before you get paid cos the sale always ends 2 hours before I get me pay XD will power says No, but Daz says get it now or forever hold your peace... Least till it's discounted higher the next fortnight lol
Didn't realise how gentle the curves are, took lots of clones to get a simple bend looking like a simple bend :lol:
Yoda says if necessary something is not, not necessary something is :lol:
Awesome, that worked! Thank you ^_^
thaz mindbending :lol:
wishing i could time bend the last few minutes. all the busy-ness last couple days made me forget my woes for a lil while. forgot i need to hold the sippy lid, nao haz coffee dribbles on my tinkerbell t-shirt. :shut: iz the sparkly tinkerbell too. my favourite. :tinksizedmegapout:
Had to clone 760 segments in a circle to get about 90 degrees of bend to work with, megapoly slowness :lol: *hugz for sparklyshirtpouting*
if you rig it to wriggle, you could have a tardis time stream :) or a wyrm hole.
i wanna get Tyler and Mikki 3 into DS. Tyler could be Gianni's lil buddy. with the right chubby morph, could be like Skipper and Gilligan.
would like to get Tyler or G2m to look like Barry Bostwick. Barry looked ruggedly handsome in Lexx, even wearing his lil red skirt.
need to get my muse whispering again by friday night. ready to pull an all nighter. 100% arabica bean.
just paid up my website bill. time to replace a dinky dragon render with some bad-ass special effects blowing dragon meister. mohawk doo for him? tee hee
hmm, it's like new klingon vs old klingon, explain the new breed or leave em guessing?
