followers
WendyLuvsCatz
I tried making a follower but nobody follows
I went step by step through a few tutorials adding a blackboard, a behaviour tree and an AI controller
all the different nodes named as said etc, a nav mesh bounds volume
tried to have two different third person blueprints one as the follower but they don't follow the just stand there idling
followed this video
irrelevent just venting but
sadly my neighbour stunk me out of my lounge with chemicals before I could try anything else, had to save and shut down my project, don't know when I can get back to it
they run a compressor and it smells like acetone, I thought they were cooking meth amphetamines but actually are doing something on their car but I have to go to the opposite end of my house and I don't get along with them so cannot say anything
anyway if someone knows a better tutorial for dummies I can watch in my room and try it again when the air is clear
you can link later a image of your behavio tree and blackboards and also you ai controller and also animation blue print, well all the stuffs you did, can be good to see what was wrong, because make a ai follow you is not hard i've made it pretty easy.
I will when I can
... was about to with that post when I suddenly had to close and shut everything down thanks to the neightbours
added that to explain why I hadn't after escaping to the other side of the house on my ipad
loading up Unreal now
am going to add a different Blueprint from the Paragon characters like they did in the video in case it's confusing the two
edit update no I have to shut down again and probably get out of the house
I deleted it all for now sorry
I will get back to this another time as stuff is too stressfull right now
I have no idea, how to do this in Unreal, but in Unity you need to bake up navigation (walkable)
on the surfaces, you wish your AI character walk and follow the player.
