Geo-graft item disappearing, HELP!
I have a geo-graft item that I am trying to fit to the DAZ Dragon 3. I go through the geo-graft process and all is fine, then I t\go to fit it to the dragon and it disappears, do anyone have a solution to this?
Did you assign the polygons of your graft to the AutoHide group? The hidden polygons would usually be the ones on the base item covered by the graft, rather than the graft itself.
Yes I did assign the auto hide polygons.
You only set Auto hide to the Graft area of the Geo-Graft. The loop of mesh that matches the base figure, not all the Geo-Graft mesh.
Okay, I will have to try that. I will let you know if it works
I tried what you suggested, but the geo-graft figure still disappears.
Figured out what the problem was. Daz Dragon 3 is autmatically sized up by 1.75 when it loads. So I had to do the goe-graft to the real size of the dragon.
