I've lost my environment option in render settings. What have I done wrong?
Please see the attachment.
I had the environment tab. If I load an old scene I saved then it's there. Now, however, it has disappeared.
Example: Start Daz. Load old scene. There's the environment options. If I manually delete everything or start a new scene it disappears to this list.
I think I was working with some old assets that have soiled my configuration somewhere but I can't find it.
Do any of you know what I'm missing? I'm sure this is easy but dang if I can find it.
Thanks in advance!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,261
    edited November 2020
    they made it a separate node
    under create tab add environment node, use parameters with it
    this is consistent with many other softwares BTW including Unreal Engine
  • AabacusAabacus Posts: 407
    Thanks!
    I don't care that things change...just that I know it's not me that fat fingered something. Lord knows I do more damange to myself than anyone else.
    Also, I literally figured this out about a minute before you replied. Thanks!!!!
  • Thank you anyway for the tips ! It helped another lads ;-)
  • LimunLimun Posts: 182
    Thanks a lot for this tip
