The content may not work as expected
On a new install of 4.6, when I attempt to load "barefoot dancer", I get the following message: "Some assets needed to load the file are missing. The content may not work as expected. The following files could not be found:" /data/DAZ 3D/Genesis 2/Female/morphs/DAZ 3D/base/PBMnavel.dsf" "data/DAZ 3D/Genesis 2/Female/Genesis2female.dsf." When I look in the data file, these files are there. When I installed, it was all default settings. I have uninstalled and re-installed. How do I fix this? ED
  • frank0314frank0314 Posts: 14,773
    try reinstalling Genesis2 Starter Essentials Male and Female
    This message is seldom wrong.
    What it means is that DAZ Studio cannot read the 'data' folder where these items are stored. You need to have the Library folder listed as a DAZ Studio Formats folder in the Content Directory Manager.
    Can you post a screenshot of your settings in Edit > Preferences > Content Library > Content Directory manager.
    How did you install Genesis 2 Female Essentials, was it through the DAZ Install Manager (DIM) amd did you also install the interactive lesson through DIM as well?
