FE dForce Irregular Skirt Punk Outfit G8F oops
Sevrin
Anyone else purchase the Irregular Skirt Punk outfit only to find that the skirt length morph actually modifies the width instead?
Oh, and the earrings are parented to the eyes instead of the ears, so that when the eyes move the earrings, move too?
LOL. Ticket time.
Post edited by Sevrin on
I don't know - sounds like a feature
Does it in effect modify the length after draping?
Could you tell me the Vert Count on the skirt and top pleeaaase? Really liked it but was holding off until I could find out about the geometry as usually impulse purchases have eleventy billion verts ;)
No, just the width.
As for the earrings, I reparented them to the ears and THEN had to use the joint editor in order to be able to adjust angle properly, because the pivot was set at the bottom tip instead of at the earlobe.
lol thats not how geometry works
it would just pleat/gather more
like draping a circle skirt with the same radius as a pencil skirt's length
but one's bum would look bigger
Quoting, because I get "Bad Request" when submitting edits
I don't know if it's a language thing. For example I love FeSoul's short hair, but the left sliders affect the right side of the head and vice versa. That's also messed up, but it's consistent and the sliders work, so it's not something I'd put in a ticket over.
Thanks for the heads up. I hadn't had a chance to unpack either yet. And you also taught me "joint editor"! I must learn to use that now.
It's a really cute outfit! I love FeSoul's aesthetic, so I wouldn't return anything, but the attention to detail needs work.
Deepnds how it is widened - it it pulled out at the bottom more than the top, which is what I was picturing since it wouldn't fit otherwise, then the length from waist to hem would increase and when simmed the result would be longer (but, as you say, with more/deeper folds).
oh I will concede this is Dforce we are discussing
not how real life stretch knitwear would behave
my polo tops don't stretch and at the same time vacuum cling to my boobs when I put them on either
and my goth like black jersey tunic dresses with the flounce around the bottom actually ride up more the looser they are ... because real life physics
no leggin friction
in the DAZ studio portal more means density and mass not swing and flap
DForce doesn't enter into it.
Base
Length 100%
Length minus 50%
I thought I'd spare delicate viewers the minus 100% length, but I think you can see which way it's going.
ah so you do have a length slider that does length not width
Something like that.
my response was to this, I don't own the outfit
Was this ever fixed?
Yeah, I don't have any of these issues.
Thanks.
