pbr works Iray doesnt
I updated to the pbr renderer and now my Iray wont render in the viewport or normally.
GPU renders? If so, how old are your drivers? 4.14 requires more recent drivers than 4.12
Ahhh. I'm not sure. I have a 2070 super
Also, Filament (assuming that is what you mean) does use some memory on the GPU - try setting the Viewport to Texture Sahded, restart DS, and see if the GPU will then render (assuming your driver is current - 451.06+).
Updating my gpu driver worked!
