Install Manager (Solved)
2»
  • fixmypcmikefixmypcmike Posts: 19,710
    It will be in C:\Users\[username]\AppData\Roaming\DAZ 3D\InstallManager\UserAccounts, you may need to have Hidden and System Folders visible to see it.
  • PlatnumkPlatnumk Posts: 682
    edited June 2014
    Located the file in
    Library/Application support/Daz 3D/InstallManager/UserAccounts (MAC Folder Structure is different to Windows)
    And no it doesn't have anything after the = sign for the OverrideManifestDir
    Post edited by Platnumk on
    I'm currently trying a different approach,
    I've uninstalled all the problem files using DIM, deleted the ManifestFiles from the ManifestFiles folder and re-downloaded everything and re-installed them.
    So far so good, it looks like that some of the original ManifestFiles may have got damaged some how.
    Will report back in a day or so and let you know if problem comes back or not
    Looks like uninstalling the problematic files and deleting their ManifestFiles, then re-downloading and installing them has done the trick.
    Thanks to all that have added their suggestions and help.
