Adding to Cart…
It will be in C:\Users\[username]\AppData\Roaming\DAZ 3D\InstallManager\UserAccounts, you may need to have Hidden and System Folders visible to see it.
Located the file in
Library/Application support/Daz 3D/InstallManager/UserAccounts (MAC Folder Structure is different to Windows)
And no it doesn't have anything after the = sign for the OverrideManifestDir
I'm currently trying a different approach,
I've uninstalled all the problem files using DIM, deleted the ManifestFiles from the ManifestFiles folder and re-downloaded everything and re-installed them.
So far so good, it looks like that some of the original ManifestFiles may have got damaged some how.
Will report back in a day or so and let you know if problem comes back or not
Looks like uninstalling the problematic files and deleting their ManifestFiles, then re-downloading and installing them has done the trick.
Thanks to all that have added their suggestions and help.
