Do Julie and Justin work in Poser 10
I just purchased Julie and Justin and I already have the clothes and I have the DSON importer.
1) When I try to load Julie in Poser 10 It seems to say it's loading but nothing appears on the screen. I tried loading it in DAZ 4.6 and it loads but I prefer Poser. I did try to export it from DAZ and import it into Poser and it worked but I'd like to know if there's something can do to get it to load directly into Poser.
2) When I try the clothes like those in Pink Ink - Poser loads it but nothing shows up. DAZ 4.6 says it can't find the DSF file and loads the shape but not the texture. I've got the DSF file and moved it into three different folders associated with Poser and DAZ but nothing works.
I'd like it to all work in Poser but if I can at least get the figure dressed and posed in DAZ and export to Poser it I'll be happy.
So How do I load the figures into Poser and how do I load the clothes at all?
Thanks for any help.
Laura
Is the folder you installed them to (not just the PoserCF, the main package as well) listed in Poser as a runtime?
And if DS isn't finding the data files or tetures it sounds like the content folders aren't set up correctly. How did you install them?
I installed the figures via DAZ Installer, So I guess it installed it into the Daz folder. There's an icon in Poser for the figures but if I click on it to open the figure nothing appears. I tried copying the files for Julie in Poser Runtime (Not just poser/download/Runtime) but she still doesn't appear.
I had the Clothes in Zip format so I just copied the folders in the zip into my download/runtime folders and then I copied them into the Daz folder that is set up in my Documents. Maybe they're in the wrong place.
Okay so lightning just struck my brain and I realized I should have the Daz folder in my library in Poser and tried to access the figure and it worked so problem one seems to be fixed. So I tried it with the clothes and it works too.
Sorry to bother you but thanks for the help attempt.
