Moved content
Hi everybody,
I just moved all my contents from c: to an outer hdd, I changed the MyLibrary location in DAZ and also in DIM. But now some of buyed products works, some not, some needs to be reinstalled and some even didn't works after reinstall..
I didn't kept the downloaded DIM data. Is there a solution wothout downloading everything?
Note: the new path contains accented letter. Can this cause any problem? A new folder is always generated..
Could you help me?
Accented characters might be the issue, yes, but it's also worth checking that you don't have any additional folders between the content directory and the /data/ and /Runtime/ folders
