Where are they?...
sheedee3Dsheedee3D Posts: 214
edited June 2014 in New Users
I just purchased the Genesis Evolutiion Morph bundle from the store...and i let the install manager install them...and it confirms that they are installed.
Only to open Studio afterwards and loading Genesis...try searching for the morphs...and they can not be found!...
Also performed a drive content scan...nothing
Please help.
Thanks for viewing.
Post edited by sheedee3D on
    You will see that they have been installed to C:\Users\Public\Documents\My DAZ 3D Library, which is the default location for DIM
    You only appear to have 2 items installed with DIM, where is your Genesis figure installed to, and where exactly are you looking for the morphs?
  • XoechZXoechZ Posts: 1,102
    After you have loaded a Genesis figure, open the Shaping Tab (with Genesis selected in the Scene Tab). There you should have a lot more shaping options than before.
  • sheedee3Dsheedee3D Posts: 214
    As you can see...the starter essentials were also installed by the install manager to the same location as the morphs...
    Still they do not appear in studio!...
    1024 x 725 - 90K
    edited June 2014
    Ok, that screenshot makes it clear!
    You have the Genesis 2 Starter Essentials installed, and the Genesis Evolution Morphs (which are made for Genesis 1). So you need to install the Genesis Starter Essentials and work with Genesis to be able to use the morphs.
    If you want to use the morphs on Genesis 2 Female, you need this pack: http://www.daz3d.com/genesis-2-female-morphs-bundle
    And this one for Genesis 2 Male: http://www.daz3d.com/genesis-2-male-s-morphs-bundle
    Post edited by XoechZ on
    edited June 2014
    They don't appear as 'Evolution' in any particular group, you just need to look for the morphs contained in the bundle.
    If you right click on the Installed tab in DIM, with the Evolution morphs selected, it will give you a list of the morphs that have been installed. My Evolution body morphs are under Actor, and are :
    ◦6 Full Body Morphs: ◦Body Builder Details
    ◦Body Tone
    ◦Emaciated
    ◦Fitness
    ◦Fitness Details
    ◦Voluptuous
    Voluptous is under Actor > Female > Real World. You need to look at what has been installed, and then find them in the appropriate area, or use the search function at the top of the Parameters pane.
    EDIT:
    Well done XoechZ, I didn't even notice that!
    Post edited by JimmyC_2009 on
    One of you guys told me that i have to install the starter essentials...but i have them installed already!...
    And as you can see under actor female...no morphs to be found!...only default.
    This is driving me insane!...this should not be so complicated!...with the V4 morphs++ it all is much simpler!...and they can be found right away!...
    Clearly something has gone horribly wrong somewhere!...only what?...and where?...
    I am thinking of doing a complete windows reinstall!...yes i know its a bit drastic...but i see no other way out...unless of course one of you guys comes with a last minute solution!...
    1024 x 738 - 123K
    edited June 2014
    Please read my post again. This should make the issue clear.
    Again: You have installed the Genesis Morph pack, which is for Genesis (1). So you need the Genesis (1) Starter Essentials. You have installed the Genesis 2 Starter Essentials. The Genesis Morphs you have installed do NOT work with Genesis 2!
  • JaderailJaderail Posts: 0
    edited June 2014
    Evolution Morphs are only in Genesis not in Genesis2Female or Genesis2Male only in Genesis.
    1283 x 925 - 194K
    Post edited by Jaderail on
    Problem solved!...
    Purchased Genesis Evolution 2 morphs...newest package...installed...all is fine now!...
    I made a quick test render...altering her face somewhat...from here on the sky is the limit!...or the limits are rather endless i would say!...
    Thx to you all for your help...much appreciated!...
    Have a nice day.
    1024 x 768 - 267K
    You still don't seem to understand there are THREE (3) Starter Essentials packages; Genesis Starter Essentials, Genesis 2 Female Starter Essentials, Genesis 2 Male Starter Essentials. You need to download and install ALL THREE (3).
