Possibility of adding marks in perspective view
daancouzijn
Hey guys,
I need to mark a certain point within the frame of my aspect ratio (9:16). Is there any way I can mark a certain middle point on a certain hight within the frame? For example, if I would like a mark that indicates the exact middle point of the perspective view, is there a possibility of adding that?
Thanks in advance!
You can turn on the Thirds Guide in the Viewoirt option menu - the lined button in the top corner or right-click the tab. Beyond that, you could mark the point in white on a black map and apply that to a plane primitive's opacity, then size the plane to match the viewport render area and parent to the camera.
Try this: https://www.sharecg.com/v/67783/browse/21/DAZ-Studio/Golden-Rules-Camera-Prop-v1.5
Ah this is perfect! Extremely helpful! Exactly what I needed. Thanks a lot!
This also looks like something I might try out for when I need a bit more complicated markings! Thank you!
Remember to set the plane's Visible in Render property to Off.
Will do so ;) Thanks
