Head Shop 11
Hey everyone,
after a recent major Update of Windows 10 Headshop does not run proper on my mashine anymore. Does anyone have similar issues?
- It starts completly normal.
- Then I select an image, which is correctly detected
- When I hit apply, an error occurs. Its german, so I try to translate "The type initialiser for "Emgu.CV.CvInvoke" has caused an exeption."
- I can hit "continue" or "exit". Exit closes headshop. When I click "Continue", it kind of works, but there are lots of unintended behaviour, which makes it useless.
I tried it with genesis 2 and genesis 8 figures and of course I reinstalled headshop. The error remains the same. Does anyone have an idea why this happens?
Here is the full error:
************** Ausnahmetext **************
System.TypeInitializationException: Der Typeninitialisierer für "Emgu.CV.CvInvoke" hat eine Ausnahme verursacht. ---> System.DllNotFoundException: Die DLL "cvextern": Das angegebene Modul wurde nicht gefunden. (Ausnahme von HRESULT: 0x8007007E) kann nicht geladen werden.
bei Emgu.CV.CvInvoke.RedirectError(CvErrorCallback errorHandler, IntPtr userdata, IntPtr prevUserdata)
bei Emgu.CV.CvInvoke..cctor()
--- Ende der internen Ausnahmestapelüberwachung ---
bei Emgu.CV.CvInvoke.Imread(String filename, ImreadModes loadType)
bei RH.MeshUtils.Data.RenderMesh.DetectFaceRotationEmgu(String filePath, Image templateImage, List`1 imagePointsInVector, List`1 realPoints) in D:\Develop\Freelance\Laslo\LLC\RH.MeshUtils\Data\RenderMesh.cs:Zeile 470.
bei RH.Core.Render.ctrlRenderControl.PhotoLoaded() in D:\Develop\Freelance\Laslo\LLC\RH.Core\Render\ctrlRenderControl.cs:Zeile 359.
bei RH.Core.frmMain.UpdateProjectControls(Boolean newProject, RectangleAABB aabb) in D:\Develop\Freelance\Laslo\LLC\RH.Core\frmMain.cs:Zeile 2480.
bei RH.Core.Controls.frmNewProject4PrintAhead.CreateProject() in D:\Develop\Freelance\Laslo\LLC\RH.Core\Controls\frmNewProject4PrintAhead.cs:Zeile 581.
bei RH.Core.frmMain.frmMain_Load(Object sender, EventArgs e) in D:\Develop\Freelance\Laslo\LLC\RH.Core\frmMain.cs:Zeile 339.
bei System.Windows.Forms.Form.OnLoad(EventArgs e)
bei System.Windows.Forms.Form.OnCreateControl()
bei System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
bei System.Windows.Forms.Control.CreateControl()
bei System.Windows.Forms.Control.WmShowWindow(Message& m)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ScrollableControl.WndProc(Message& m)
bei System.Windows.Forms.ContainerControl.WndProc(Message& m)
bei System.Windows.Forms.Form.WmShowWindow(Message& m)
bei System.Windows.Forms.Form.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 4.0.0.0.
Win32-Version: 4.8.4250.0 built by: NET48REL1LAST_C.
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll.
Rh.HeadShop
Assembly-Version: 1.0.0.0.
Win32-Version: 1.0.0.0.
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/Rh.HeadShop.exe.
Win32-Version: 4.8.4270.0 built by: NET48REL1LAST_C.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
RH.Core
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/RH.Core.DLL.
System
Win32-Version: 4.8.4200.0 built by: NET48REL1LAST_C.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
Win32-Version: 4.8.4084.0 built by: NET48REL1.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
System.Configuration
Win32-Version: 4.8.4190.0 built by: NET48REL1LAST_B.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
FaceSDK.NET
Assembly-Version: 6.2.0.0.
Win32-Version: 6, 2, 0, 0.
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/FaceSDK.NET.DLL.
msvcm90
Assembly-Version: 9.0.30729.9625.
Win32-Version: 9.00.30729.9625.
CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_508ef7e4bcbbe589/msvcm90.dll.
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
OpenTK
Assembly-Version: 1.1.0.0.
Win32-Version: 1.1.1536.5788.
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/OpenTK.DLL.
RH.MeshUtils
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/RH.MeshUtils.DLL.
RH.AssimpNet
Assembly-Version: 3.2.0.0.
Win32-Version: 3.2.
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/RH.AssimpNet.DLL.
OpenTK.GLControl
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/OpenTK.GLControl.DLL.
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll.
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll.
mscorlib.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
System.Windows.Forms.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
Emgu.CV.World
Assembly-Version: 3.3.0.2824.
Win32-Version: 3.3.0.2824.
CodeBase: file:///F:/Daz/DAZ%203D/HeadShop%20plugin/Emgu.CV.World.DLL.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
Have you considered to email for tech support?
[email protected]
Hello,
I could fix it and want to post the solution in case others encounter the same problem.
I uses Windows 10 Pro N with a manually installed media feature pack. This pack was automatically unistalled with the major windows update. The missing files caused the problems in headshop, so a reinstall of the media feature pack fixed the problem.
The tech support seems to be very helpful by the way.
