Stop Poses From Resetting The Size of Figure
I have several poses I created for my figures/models that resets them to 100% in scale when I had already sized them down smaller or higher. I'm not sure but I think it may change their measurements as well. How do I make the poses work with the measurements I've given to my figures?
    You can double click while applying a pose (preset) and you get a pop up. Disable the scaling transformation will help, probably.
  • Paintbox said:
    You can ctrl-double click while applying a pose (preset) and you get a pop up. Disable the scaling transformation will help, probably.
    FTFY.
    FTFY.
    TYFTFTFY
  • Thanks for the info, but I don't get anything for scaling transformation. The pop up I get is Pose Preset Load Options.
    You should a box that allows you to control transformations, uncheck what you don't need.
  • PetraPetra Posts: 1,157
    Once you used the scaling in the parameter box,  you can click on the little lock, to lock it and it will stay that size.
    Like this:
    476 x 513 - 108K
  • Thank you, all. Now I get it. I was looking for it in the wrong place. Thanks a bunch for the help.
