Store Credit display issue
SimonJM
As part of the new store it seems that Gift Cards have a new format for their codes - plus teh email giving details no longer 'auto-fills' that code (you used to click on the code in the email, now you have a button; which is, at least, more obvious if not less useful!). However, when goign to check it has added (I am paranoid!) I was a bit non-plussed by the display page for Store Credit, the format of which has alos changed - primarily it is no longer in proper date order!
This is a known issue, but probably not a priority issue as liong as the balance is correct.
Understood, even if (potentially!) solved by a simle ORDER BY clause
Now working as expected
