Genesis 8 female figure loads in muscular
Whenever I load in my Genesis 8 female figure it loads in extremely muscular and I cannot get the body shape back to the way it is supposed to be.
Attached is an example
Please put the Viewport in Smooth Shaded mode or apply some clothes to the figure.
This is likely to be a morph that was saved with a non-zero default value, so that it loads set on every Genesis 8 Female figure that doesn't have it explicitly set to 0. If you look at the Currently Used group in the parameters pane you may be able to see it - from the name you should be able to figure out the culprit and ask for a fix, from the artist or from Daz support if it came from here. You can fix it yourself in the meantime - load the Developer Build version of the Genesis 8 Figure, Edit>Figure>Zero>Zero Figure, then File>Save As>Support Assets>Save Modified Assets (though this will not work if it was a Daz character that you installed through Daz Studio itself).
