DIM updates
Not sure if is only me or anyone else has same problem. Dim keeps saying there is update, i click install, dim is closing and...nothing happen. Could someone from daz share link to this update so I can download it manually?
Post edited by martin36 on
same here; downloading but next start same update window
Yes, I have that today.
It is mentioned here https://www.daz3d.com/forums/discussion/447446/store-issues-known-problems-please-read#latest by DAZ_Rawb that they try to fix some issues with DIM and are now working on the misleading "Update" note. I suppose it makes no sense to use DIM for the newxt few hours.
Well first I had the "no items on Download tab" problem, then I got the update problem, but now everything finally seems to work.
@taoz Did you get the update notice AND install it, then your column populated? I am not getting an offer of an update at all (and still nothing in Ready to Download)
No, I got the update notice and let it "update", but it just shut down after a while. Did that three times. Then a little later I tried again, and everything worked.
DAZ_Rawb said elsewhere that they were working on both problems, so looks like they managed to fix it. He also said that the no Downloads problems seemed to hit people with many products so if you have/had it too, that makes sense.
My DIM is working now but all the files are showing as ready to download. There are no installed files. The paths are all correctly set. I hope this is just a temporary issue
My DIM is finally working, I had an update for one of my outfits this morning. And my older files of Poser and old Daz products I haven't installed returned to available to install again. That is good to see if the Daz files don't have the needed geometry and I need the Poser files for them.
A little bit of my life is restored.
i got it and installed... it worked, but it was the same version. One thing though, most of my products already installed in Daz Studio indicate they need to be installed, so something got messed up.
I completely lost my DIM all the files are gone, I tried a total reinstall twice. Sadly I need the 32bit DIM and the only one available is the 64. Fortunately I have a copy of DIM 32 but its not working. I think I am going to have to go old school and install everything the old way. Is any one else having issues with DIM does anyone know how I can get another DIM 32 and may be just may be I might be able to use it again.
Still an empty Ready to Download pane for me. Nothing shows up. Everything already installed is there, but nothing for download. This is day five without it.
Yes, there was no update - it was just a side-effect of the store change.
This thread is reporting issue and fixes (DIM should be fixed now, so if it's still not working for you please post there) https://www.daz3d.com/forums/discussion/447446/store-issues-known-problems-please-read/p19 .
Try here https://www.daz3d.com/downloader/customer/files#prod_14810
