zeroing a pose [solved]
AbnerK
when you watch a tutorial, they'll zero the pose and it's goes instantly. When I do it, even on this new, fast computer it takes an age. Is that normal? Do they just edit out the delay on the tutorials, because there's a lot they don't edit out that they really should half the time. :) I often find it's quicker to zero a pose manually.
Post edited by AbnerK on
The more dials you have for the figure, the more time it takes to zero. Often it is faster to use zero-poses from the product library
ah, I used to have one saved as a favourite on my other computer but, I wasn't sure if it was quicker or not. I'll give that another go. Thanks.
It actually also worked on zeroing a pose that the Pane option nor the manual method wouldn't fix and it was fast. Thanks.
