Daz3d, View: Pan - with middle mouse button..? Can I configure it.
41afe24c1f41afe24c1f Posts: 0
Hi
the first time I used Daz3d I thought it was obvious that I can move my view around while holding down MMB (because in most D3 applications you can do that).
1. I want to eliminate the fact that I have to click and hold down the virtual 'View: Pan' button in order to move my view..
2. When I hold CTRL and then press MMB I would want to rotate the view
I can't find any tutorials that would teach me how to do that, that leaves me wondering...... is this.. even possible?
Thank you.
  • Richard HaseltineRichard Haseltine Posts: 109,459
    edited August 2025
    Go to Window>Workspace>Customise and look at the bottom of the dialogue - select the function you wish to edit, right-click double-click the current short cut to get the change option, and click/press the combination you wish to use.
  • 41afe24c1f41afe24c1f Posts: 0
    Go to Window>Workspace>Customise and look at the bottom of the dialogue - select the function you wish to edit, right-click the current short cut to get the change option, and click/press the combination you wish to use.
    Thanks :D! It's exactly what I needed.. it's working.
  • YES!! That was frustrating me, too.
  • JeremyDJeremyD Posts: 265
    Excellent I need to do this! (Sometimes it's so jarring going from another 3D application to Daz in the same workflow)
  • NovicaNovica Posts: 23,925
    Learn something new every day! I wasn't aware it could be customized and have been doing it that way for a couple years. Thanks Richard!
  • and to think I just accepted it for what it is all these years...
  • This should be a standard, it's so frustrating working with daz, it's so unintuitive...
    The problem is that there are multiple standards for viewport navigation, your experience may lead you to expect middle mouse button but that is not universal.
  • teodell_70teodell_70 Posts: 10
    edited August 2025
    Hi. I'm still having trouble. When I right click the option at the bottom, say for Orbit, it just turns Orbit a dark gray and doesn't seem to record the next key(s) I press for the shortcut. I know Daz 4 I either figured this out or it was default for Orbit as Middle Mouse Button.
  • rosselianirosseliani Posts: 512
    edited August 2025
    I think they changed the procedure:
    Go to Window>Workspace>Customise and look at the bottom of the dialogue - select the function you wish to edit, right-click double click the current short cut to get the change option, and click/press the combination you wish to use.
    1221 x 945 - 135K
    1232 x 939 - 133K
  • Sorry, yes it is double-click to edit those rather than right-click (in DS 4 too). I will correct my original post, but leave the quotes so people can see why it was confusing.
