Spline to mesh
tomahalktomahalk Posts: 0
Hi!
Am I able to change a spline/vertex model to a mesh model? How? I want to import to Second Life
Thanks!
Tom
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    tomahalk said:
    Hi!
    Thanks!
    Tom
    Have you tried
    Menu "Edit" Item "Convert to other modeler" then choosing "vertex modeler" as the target modeler?
  • tomahalktomahalk Posts: 0
    Thanks so much!
    Maybe, you know the answer to this. In uploading to Second Life, it says"missing the required level of detail; Does this me add vertices? Probably, right?
    Thanks!!!!!
    tomahalk said:
    Thanks so much!
    Thanks!!!!!
    That's kind of a cryptic message, it might also refer to the textures....?
    Better ask on a Second Life forum...
    Okay Thanks again.
    Funny how computers always give us these unintelligible answers. Who do they think is the reader of these? :)
    tomahalk said:
    Okay Thanks again.
    Blame the programmers, not the computers. The programmers write the error messages and assume everybody else understands the syntax.
    The other thing to consider when converting a spline object to a vertex object is that the conversion generates a mesh full of triangles instead of quads. This may be a problem with some programs. You may need to go into the vertex modeler and clean them up. Check the forums for the game you're looking to make a model for.
  • HeadwaxHeadwax Posts: 10,430
    edited June 2014
    http://wiki.secondlife.com/wiki/Mesh/Troubleshooting
    looks like there is an error log which will guide you on your way....
    I'd say it's probably a case of negative scale detected, unsupported transform. domInstance_geometry:
    so if you fix that you cant go wrong....
    do they still 'play' second life? I have enough trouble with my first life....
    Post edited by Headwax on
