Install Manager
SaitoSaito Posts: 38
is it possible to reset your downloads from your install manager ? if so how?
  • Dumor3DDumor3D Posts: 1,316
    What do you mean by 'reset'?
  • fixmypcmikefixmypcmike Posts: 19,689
    Do you mean re-download an item? Was it installed with DIM, or is it sitting in Ready to Install? Is it no longer installed but DIM thinks it is?
  • JaderailJaderail Posts: 0
    Reset is as simple as uninstalling from the Installed tab for a single item in DIM or many if you like. For a full new Reset of all content your talking much more work, both in DIM and DAZ Studio. But doable also.
  • SaitoSaito Posts: 38
    Basicly i want to take the DIM and all that is in it and install it in another pc later. but i have bought items from daz from an old account that i cant even remember the user name or PW, cause the email used i quit using. is it possible to transfer the info using flash drive the installing it in another pc
  • DAZ_ann0314DAZ_ann0314 Posts: 2,876
    It would be better for you to contact customer service and give them your name and info and have them find the other account for you. I would assume if you purchased items in the past your general info should be the same so it shouldn't be a problem for them to find you and help you get your info updated :)
