March Madness Coupon, not valid?
BorgBoy7
I have earned up to $50.00 towards DAZ Originals in a single purchase.
However it is saying that the coupon code is not valid.
Am I just too early for the code to be active yet (8:00 AM Seattle Washington).
Also, if I go over $50.00 I just get charged the difference, right?
Jessica dress is still in the "New" category so it doesn't apply...
IIt should work for the Freak 5, though.
The code is broken. It has already been reported to DAZ, so they will fix it when they are in office. :-)
Yes it has been reported to DAZ
It has been fixed. The coupon applies now properly.
Thanks for the help, the coupon is now working. :)
I am still getting a coupon not valid error. I have 4 items in my checkout, none of which have the green 'new' banner across the picture in the store, none of which are under $3 and all which have the Daz Originals logo.
I have a request in to support, with supporting screenshots.
What products are you trying
Cargo Shorts and Tee for Genesis 2 Male(s)
Cargo Shorts Textures
Internship Outfit for Genesis 2 Male(s)
Internship Outfit Textures
There have been issues before with items that have just come out of their 60 days new item phase and coupons. You might want to raise a support ticket or try some other items. Those items look to be just past the 60 day mark.
I started a near identical thread in Members only.
My voucher was not working but now it is...seems someone kicked the web editor because a wrong bundle item was showing up as punchworthy. That has been swapped at the same time the voucher seemed to start working...
Sorry to warm this thread up again, but I've had the same problem today (May 30th 2014).
What code did you enter, and what did you use it on?
The Code was 05-14PlatClub and I used it on the items below. I've sent an email to the support team, just want to make sure the system is working fine.
The only DAZ original item in that order appears to be the moon lander and that one is a free item with platinum club. It dos not work on non-DAZ originals, so I'd expect it to fail there.
Ha, I never knew that - I had always assumed it's off everything. Thanks for clearing that up!
