v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
1567810
  • mCasualmCasual Posts: 4,607
    luckily, i did one last test and found a problem for scripts making heavy use of parenthesis
    it's now fixed
    so basically it's ready ! and i'm heading to my web site !!! ... soon
    coffee, packaging, uploading
    badabing
    910 x 910 - 324K
    edited May 2014
    * * * B E T A -- 8 -- * * * B E T A -- 8 -- * * * B E T A -- 8 -- * * * B E T A -- 8 -- * * * B E T A -- 8 -- * * *
    ready and tested 36 times with Daz Studio 4.6
    https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera
    tomorrow i'll update the manual and tell you about the secret feature
    273 x 273 - 15K
    Post edited by mCasual on
  • RAMWolffRAMWolff Posts: 10,344
    What I find amazing is that you can get SO much functionality out of a script that's the size of a note written in Note Pad! lol
    edited May 2014
    reminding that Beta * is released and compatible with Daz Studio 4.6
    it was tested on 36 of the sample path scripts
    also, today i updated the manual to show the new features
    the new features are mostly for advanced users with some programming experience
    they let you access everything in the scene, for example, here mcjBuilder let me build a belt and a dress edge directly on the Aiko3 bodycon - all this in Daz Studio
    in the second image, a tube was built on the path of Amy's finger tip ( node -tracking )
    in the third image, the position of the extruder node was used to modulate the height of the 144 blocks
    960 x 960 - 133K
    320 x 320 - 33K
    910 x 910 - 141K
    edited June 2014
    there seems to be a problem with the endcaps
    though with some profile curves ( like "square" for example ) it doesnt seem to occur
    for the shelf below, i seem to have to select the "shelf" profile using the drop-down list
    before starting the build process ( which makes use of that profile )
    ... i think it's because the tesselation ...yeah that's it
    the part of mcjBuilder that creates endcaps uses the drawn
    curve of the preview window and that curve must be
    corrupted or worse it must be the path curve
    so later today i'll post version Beta 8.1 with endCap fix
    figure 3 and 4 the bookshelf was made with the following mcjBuilder Beta 8.1
    which will be released incessantly!
    it will also include the new "shelf" profile and the following "shelf" path-script
    Profile shelf
    Tread 1
    pathUnits in
    MoldSize 12 0.75
    var w 48
    var thick 0.75
    var depth 12
    define ashelf
    setScaleY (thick-6/32)/thick
    setScaleX (depth-6/32)/depth
    ring
    endCap
    setScaleY (thick-3/32)/thick
    setScaleX (depth-3/32)/depth
    ring
    Move 3/32
    setScaleY 1
    setScaleX 1
    Ring
    Move 3/32
    Ring
    move w-2*thick
    ring
    Move 3/32
    ring
    Move 3/32
    ring
    ring
    endCap
    break
    defineEnd
    SetPosZ 0
    ashelf
    MoveY 24
    repeat 5
    SetPosZ 0
    ashelf
    MoveY 12
    repeatEnd
    Set w 74
    RotateX -90
    SetPosZ -3/8
    Repeat 2
    SetPosY -3/8
    ashelf
    MoveY -48+3/8
    repeatEnd
    1920 x 1080 - 209K
    1920 x 1080 - 407K
    1920 x 1080 - 230K
    1440 x 489 - 94K
    Now ya just books! lol
    i'm inspired by a pov-ray render named the office
    http://hof.povray.org/office-13.html
    so far mine is like
    1920 x 1200 - 510K
    Now you just need to figure out how to add in fancy details like some book shelves have...
    Here is a fun search!
    http://tinyurl.com/orfpmmb
    edited June 2014
    * * Beta 8.1* * Beta 8.1* * Beta 8.1* * Beta 8.1* * Beta 8.1* * Beta 8.1* * Beta 8.1
    * * fixes an issue with endCaps * *
    and includes more sample paths and profiles
    ( walls with windows? yep )
    1920 x 1080 - 1M
    273 x 273 - 16K
    I'm tellin ya man. DAZ ought to make you an offer on this code and integrate it into DAZ Studio!
    edited June 2014
    Next weekend probably ... Beta 9
    fix : issues when a "defined" block of commands calls other "defined" blocks of commands using identical parameter names
    fix: parenthesis
    add: "stud" command which builds round-edged studs
    add: new profiles
    add: all the mcjBuilderA paths used to make the walls and doors and windows shown below
    the walls and doors and windows shown below will also be distributed as props
    1920 x 1080 - 508K
    1920 x 1080 - 1M
    1920 x 1080 - 560K
    1920 x 1080 - 2M
    1920 x 1080 - 1M
    edited June 2014
    studs smooth-edged arcs
    figure 3 shows the shrink command which can be used to chamfer complex (non convex ) shapes
    1920 x 1080 - 1M
    1920 x 1080 - 1M
    1920 x 1080 - 623K
    1920 x 1080 - 924K
    Looks fantastic Casual! Thought this thread went very quiet for a while....
  • Miss BMiss B Posts: 3,071
    Yes, glad to see some activity in this thread again. :coolsmile:
    thanks!
    while making this ( promised ) movie set, i'm finding things to fix in mcjBuilder
    so this explains the upcoming version 9
    next i'll finish the stairs for the mcjCastle
    then turn the mcjCastle into a real prop with openable doors
    then we go back to the physics simulation and Amy's BMX stunts
    unless i make a Kinect-to-Studio detour
    600 x 800 - 87K
    well as you could see i started a few other threads while i was "away" from this one :)
    1920 x 960 - 772K
    It occurred to me your either a wealthy person or retired to have this much creativity and time to produce all the great ideas that flow around in your minds eye. lol
    edited June 2014
    it's neither, it's just that i 've been programming since about the year of the release of see-below and work mainly as programming and electronics (digital mostly ), so this daz scripting hobby isn't that demanding - i complete those projects much slower than i'd like
    though my first programs were typed on a noisy telex and stored on punched paper tape - the PET was just what dreams were made of
    1920 x 1280 - 1M
    800 x 800 - 42K
    WOW.. one of those code people from way back when. YIKES! Well glad you enjoy that sort of thing! :-)
  • Robert FreiseRobert Freise Posts: 4,583
    I remember those machines
    Yes Sir, I most definitely noticed. :coolsmile:
    well it seemed like a distant dream, but here we are almost 6 months later , ready to resume work on mcjBuilderA
    our test subject is the creation of a movie set used in many kpop videos - it will be posted as free props.
    once that's done i'll create new stairs for the mcj castle
    then turn the castle in a fully animatable prop
    then we'll return to bullet physics and BMX jumps
    then there's the cage deformer project, 3d painting, kinect mocaps
    and other projectsi almost forgot like OPENGLwater and grass
    and other projects i really did forget
    1920 x 1080 - 560K
    Awesome sauce! lol
    edited December 2014
    version 9 will have a "shrink" command
    which should help us get better looking extrusion lids
    var tr 250/46
    Tread tr
    define bar x y len w h
    profile carolina
    moldSize h*tr w*tr
    setPosX x
    setPosY y
    setPosZ 0
    setShrink 0.3
    Ring
    endCap
    Move 0.1
    setShrink 0
    Ring
    Move 0.3
    Ring
    Move len-0.8
    Ring
    Move 0.3
    Ring
    Move 0.1
    setShrink 0.3
    Ring
    endCap
    break
    setShrink 0
    defineEnd
    1236 x 697 - 246K
    the end caps are still non-welded
    which was a necessity when we didn't have the shrink command
    because the triangulation method used for the caps
    produces badly behaving triangles
    but now .... maybe i'll add a "weld-caps" option
    ( who knows maybe someone will 3d-print objects made with this ! )
    Figure 2 shows the same non-welded object, with (legacy) catmull-clark subdivision
    using the new DS4.7 default subdivision method produced a ''leaky'' mesh
    1920 x 1080 - 728K
    1920 x 1080 - 662K
    My question about how the verts are laid out, how does a seamless tile look or is that impossible for such a layout?
    the UV layout is ideal for tiling
    the 2 "caps" are planar projections
    the "tube" is a very carefully un-rolled and there's as little stretching as can be
    1920 x 1080 - 620K
    1296 x 644 - 169K
    HAHAHAHA.... OK... great to know! ;-)~
    the "shrunk" UV layout issue seems solved
    i think i can now return to acid-testing mcjBuilderA Beta 9.0
    i.e. creating the gothic movie set with it
    the difficult thing was, that the rest of the UV layout is based on the movement of the extrusion nozzle
    but, in the case of shrinking, the nozzle doesn't move, it just contracts/expands
    1920 x 1080 - 980K
    Nice and clean!
