genesis 8 female does not deform correctly for poses and animation
OK, so I have been using Gen8 female for poses and animation and the model deforms incorrectly. If I use a pose that bends the legs it starts to look weird. Here are some screen shots. I submitted a ticket to DAZ over 2 months ago and no reponse to this problem. If anyone else have dealt with this issue and have ound a fix please let me know. Also I've tried the latest version of Daz and it still has this problem.
The keel at the back looks like the issue that https://www.daz3d.com/big-girl-morphs-for-genesis-8-female had on first release, if so just redownload from your account and reinstall (this came up the other day and I did check that the current download has the fix).
I don't have big girl morphs for gen8 female.
It certainly isn't normal behaviour, so something is installed incorrectly.
See what the minimum pose you can use to trigger the distortion is, then in the Parameters pane option menu (the lined button in the top corner, or right-click the tab) enable Preferences>Show Hidden Properties. Go through the Currently Used group trying to zero things until you find which properties cause the issue - what are their names?
Am I looking at morphs or pose controls? Everything I can see in Parameters are already zeroed out. Unless Im missing something.
OK so pjCMBGMGGluteSmooththighsbend90 was one of the problems. I zeroed that parameter and it helped the pose. Is that the solution? Just zero out the ones that are messed up?
The name of the file sounds like BigGirlMorphs, but the the readme and file list is inaccessible at the moment, so can't check.
If you have the Big Girl Morphs redownload from your account and reinstall.
Hey that worked it was Big Girl Morphs I didn't even know I had that in my library. Thank you for your help. Deeply appreciated.
