DELETE
davesodaveso Posts: 7,886
edited October 2021 in The Commons
DELETE
Post edited by daveso on
  • FSMCDesignsFSMCDesigns Posts: 12,846
    The lenses don't come off, but it's easy to clean (microfiber cloth always). see this video
    if it's blurry, try playing with the IPD settings (move the lenses side to side). I assume you did pull the plastic coating off the lenses first. Also how it sits on your head/face also affects the sharpness.
    Mine is rather sharp with no issues, matter of fact I am wearing it now as I check the forums.
  • davesodaveso Posts: 7,886
    edited October 2021
    DELETE
    There is also a glasses spacer that comes with it if you haven't tried it yet.
    Is this your first headset?
  • MadaMada Posts: 2,045
    Getting the right IPD is important, and if you usually wear glasses you have to wear them with the headset too. Best way to check if its actually the headset is for someone else to look through as well and see if they have the same issues. Positioning it in the right spot helps a lot to focus as well.
    Also did you maybe leave the headset in sunlight? Bright sunlight on the lenses can damage it within seconds
    edited October 2021
    DELETE
    edited October 2021
    DELETE
