Razor Thorn for G2F & the RSSY clothing converter?
The G2F to G8F converter generaly works okay except for the angles of the back wings & arm blades.
Is there an option to adjust the angles of the wing & blade components?
Thanks;)
Thanks;)
Those extra blades and whatnots had their own bones and rigging, which unfortunately get stripped out during the conversion. Even the face groups are reassigned to standard Genesis 8 bones (i.e., the back blades' polygons are distributed over at least 6 body parts, whichever was closest), so a more meticulous manual process might be needed to retain or restore the full functionality. Lots of work, there.
Alternatively, you could look into D-Formers that can be saved with the new outfit and adjusted as required, like any morph. You would use them instead of standard posing, where the bones would be rotated as needed. There aren't any poses for the outfit, so you would have to position them manually either way.
I vaguely remember a tutorial by sickle that explained how to transfer clothing without losing extra bones. I think it was on deviantart or something.
Thanks I'll start searching;)
I take it you mean Sickleyield?
I sure do :)
The tutorial is for G3F but it kind of works with some mesh smoothing.
Doh, tried animating and sadly it doesnt work.
