Dforce Hair issue
Need help with this one Hair only displays the scalp part in Iray
it's Dforce Faye Hair, same thing happens with Lea Hair 1 and 2
am i missing something ? i reinstalled the hair twice already, samething
btw this only happens in Iray Preview, in render it works fine
After I increased the line Tesselation to 2 it sightly changed in preview [ Pic 3]
    With this sort of hair the preview does not show the same as your final render will show.  This is quitte normal
  • thanks for the reply. I thought i was missing a file or that DIM or I messed up the install
    Is there anyway to get to show normally like other Non-Dforce Hair do in preview ?
  • Yes there is, somewhere [don't recall exactly atm where] a switch to toggle the view on. Some such hairs have a preview toggle on/off script in their folders.
    However it is off for a reason.
    Often these hairs are very heavy and will bog down the mobility of the scene as one tries to work with the other models in the scene.
  • Thanks
