Sci Fi Prison Corridor - Network error when downloading from DAZ
kenmokenmo Posts: 1,131
edited October 2020 in Daz Studio Discussion
Just purchased this item https://www.daz3d.com/downloader/customer/files/prod/21590/
And getting a fata network error when I attempt to download the item.
I tried Daz Central several times and get the same error. So I tried Daz Install Manager several times with the same results.
A manual download did not work as well.
Other tiems have downloaded successfully today via Daz Central.
Is there a problem with this item?
Cheers & many thanks...
Post edited by kenmo on
  • The whole site seemed to be labouring, please try again. Also, if you want to link to a product please use the store page not the Product Library page - only purchasers will be able to see the latter - in this case, https://www.daz3d.com/sci-fi-prison-corridor
  • kenmokenmo Posts: 1,131
    ???? Not sure I know what you mean by that comment and it DOES NOT assist me with my problem....
    I just tried again. Same error. Can someone from DAZ advise if there is an issue?
    I was pointing out that the link you posted is not useful to people who do not have the set, using the link to the actual product page is better.
    As i said, people have been having issues off-and-on for a little while, trying outside busy hours may help. If not then you need to contact Daz, the forums are not Daz support and can't usually give an official answer.
  • I am told that Daz is aware of there being a lot of failures and they are looking into the issue.
    Thanks for the update. I tried again and it's past midnight on the east coast of Canada (Nova Scotia) and still getting an error... Wanted to buy some more stuff. Guess I'll have to try tomorrow.
    I was able to download this morning. Cheers & many thanks...
