DAZ Studio crashes
Hello,
I don't understand, Some scene I use to open before can't be open without a crash ... and rendering don't talk about it... I try to simplify the scene, but I eventualy need to create more crowned and complex scene...
Help
  • Looks as if you have only 4GB of RAM, that's going to be very tight for anything - even quite a small change in DS or the environment could tip it over the edge, and indeed the error appears to be complaining of a lack of memory.
  • Fact I have 8GB VRAM and 64 GB of RAM ...
    I don't understand
    643 x 188 - 21K
    810 x 751 - 83K
  • That's not what the log seems to say:
    -<memory><load>73</load><totalphys>4219715584</totalphys><availphys>1270853632</availphys><totalpage>1457762304</totalpage><availpage>304283648</availpage></memory>
    (unless I am miscounting digits).
  • but how??? as you can see, I really have 64 GB
    is it VRAM problem?
    Should I reinstall all my DAZ Studio and librairy?
    Should I reinstall all my system?
    550 x 83 - 13K
  • I don't know - it appears to be reporting on system RAM, and gives swap sizes which don't apply to GPUs. I did wonder if it was the 32 bit DS, but it appears not (at least from the path).
