Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)
1656668707174
  • Hun73r3dxHun73r3dx Posts: 38
    edited October 2020
    Hun73r3dx said:
    Seems like your not allowed to write anything in this snow
    Hun73r3dx said:
    No i did not i just updated the beta the driver that i have is from the 7 month its the latest.
    Latest driver is 456.71 which is definitely not from July but from October.
    I am using the latest driver if you have bothred to read also its in shaded viewport and i dont use Iray i use octane.
    From what you said above it doesn't seem like you do.
    Octane is integrated into and relies on DAZ Studio, if DAZ Studio needs latest drivers so does Octane. You cannot update to Beta which requires new drivers then refuse to update drivers and complain how it doesn't work.
    Dont you understand i run the latest driver i run 456.71 that is the latest driver
    How do you expect us to understand when you wrote "the driver that i have is from the 7 month its the latest."
    Month #7 is July.
    What is your problem with beta anyway? Did you check if there is an update for Octane perhaps? Maybe it can't work unless updated to match the new beta.
    i read the date wrong when i went to the site the first time, this time i went to the eu site of nvidia
    Also if you read the version number you could see it was the latest driver.
    Post edited by Hun73r3dx on
  • FrankTheTankFrankTheTank Posts: 1,535
    edited October 2020
    So is anyone else having these problems shown below, especially animators, I wan't to know before I risk screwing up my install of Daz, everything works fine with 4.12.0.86 and I would like to keep it that way. If the beta is going to cause new problems, I won't be risking it.
    Hun73r3dx said:
    Newest beta makes my pc lag just moving the mouse inside the viewport makes daz use 100GPU on my 2070s
    Moviehawk said:
    My system keeps freezing up when switching between panes in the animation timeline - using the new Beta - used Task Manager to fix. Had to uninstall and reboot to remove the problem.
    Still having sporadic freeze issues running older versions  of Studio - even though the Beta is uninstalled. Never had these problems before??
    I wonder if some common files may have been updated - and not reverted with a uninstall?
    Or - could just be me!
    Post edited by FrankTheTank on
  • Saxa -- SDSaxa -- SD Posts: 882
    edited October 2020
    4.12.0.86 is regular release.  This is Beta Public release. Regular & Beta are separate.  You have both installed and can run both programs at same time (do this all the time.)
    Am still on 4.12.0.86 and also using latest *.54 Beta.  Only wrinkle between 2 programs is updating/syncing your profiles because they are separate (which can be good, has helped me troubleshoot various DS issues withoiut open support ticket).
    More animators providing feedback to DAZ the better, so hopefully u add this Beta (you may have to "buy" from store before you can DL.), and provide any feedback to DAZ via ticket system.
    Post edited by Saxa -- SD on
    yes, I know it is a beta release and it shouldn't interfere with the regular release, but if you notice what Moviehawk said above, it sounds like something in the beta install may have caused problems with the regular install. I just want to make sure that is not the case.
    edited October 2020
    Mmm, didn't have time to read the last bit.  Just skimmed the start of both of quotes which referred to Beta issues sans Regular.
    I didn't have any problems.  Had a very long session with both open.  But still on Win7prox64 with 64gb ram and latest video drivers.
    Having gone through the directories of the 2 setups several times, I remain with impression that they are very discrete setups, except CMS and content manifests.  The person with the isse could maybe clear the cache in roaming profile as that is shared.
    Edit:  Just remembered one Daz trick that seems to help me from not crashing. When am done any activity like Daz-Hexagon bridge for morphs, or especially loading a new scene, always close out Daz session first.  And yeah I made my own batch file so it shuts down in 1 second flat.  Been doing this for a year without ill effects, despite not DAZ-officially-recommended (ie. no support).  That fresh reset seems key as DAZ and RAM memory seems to be not perfect yet.  Mention this futher to my comment about not having an issue after a long session (8 hours plus) with both running.
    Running on Win7 can also shield from W10 related problems.
  • Tried to render in the beta and still getting a gpu error with the latest studio driver
    The scene renders fine in the general release, just in the beta it jumps to cpu
    2116 x 1177 - 1M
  • My Freeze-up problem still persists - but is very localized to the Animation graph editor. Studio will work for a number of minutes, or hours - but then I point-click on the graph and - freeze! So far I have been able to break out of it by hitting ctrl+alt+del to bring up the task manager (sometimes  have to do this 3-4 times), save the file, but then have to re-boot my system to clear whatever the problem is.
    What is this Clear Cache/Roaming procedure? Never heard that one before.
    Still using Studio version 4.12.0.86 - but has been working fine for the past year (on my Dell 9020 system) and only starting to freeze after the install of the Beta.
    Uninstalled the Beta, but problem still there. There have been no Windows updates - but I did update the Nvidia driver hoping that might solve the problem - but no luck.
    I did file a report - no response yet.
    Thanks
    Alan
    @Moviehawk, have you tried uninstalling and reinstalling 4.12.0.86? I would really like to test the beta, but don't feel confident enough to risk it based on what you're experiencing. I definitely need to be able to use the graph editor.
  • MoviehawkMoviehawk Posts: 67
    edited October 2020
    No! Not going to take that risk. It might break something else.
    Also - can't uninstall/reinstall older versions - unless someone knows where to the the manual install files.
    Yes - using the graph editor is where I have problems - but so far it is just a PITA! I've been able to recover from the freeze events - but you never know - so I need it to be fixed, or some solution where I feel safe using the software again. It could still be my system - not hearing much of the same problem from other users.
    Side note: (When it rains it pours!!!) Tried installing the beta on a backup system - same results - but now dForce fails to run. It just sits there spinning and I have to crash out of the program - left it run for over 30minutes - 0%. SImple stuff - easy clothes props and a plane, nogo! All was working fine prior to installing the Beta!
    Alan
    Post edited by Moviehawk on
  • kyoto kidkyoto kid Posts: 42,109
    ...yeah, while 4.12.0.86 was a Production Release it was superseded by 4.12.1.118 (which the current Production Release) so yes 0.86 would no longer be available to reinstall unless you manually saved the installer (which is what I routinely do each new update, production or beta, so I can roll back to the previous one in case the newest release still has bugs or instabilities).
    Alan
    Does the beta installation update something in Windows 10? That would explain why removing it wouldn't fix the problem.
  • Update the highlight thread already, please. It hasn't been touched since April.
  • Hi,
    Report bug with 4.12.2.54 DL today.
    I dont have a problem with Daz 4.12.1.118
    Viewport Nvidia Iray not work with gpu card but work with cpu.
    Part of log file :
    2020-10-22 19:27:05.770 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4 Public Build\shaders\iray\resources\DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2020-10-22 19:27:05.793 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2020-10-22 19:27:05.794 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2020-10-22 19:27:05.795 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2020-10-22 19:27:05.795 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2020-10-22 19:27:05.796 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (0 triangle objects with 0 triangles, 0 fiber objects with 0 fibers (0 segments), 0 triangle instances yielding 0 triangles, 0 fiber instances yielding 0 segments) took 0.000s
    2020-10-22 19:27:05.796 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2020-10-22 19:27:05.796 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 0 textures, 0 lambdas (0 unique)
    2020-10-22 19:27:05.796 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2020-10-22 19:27:05.819 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2020-10-22 19:27:05.821 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2020-10-22 19:27:05.821 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2020-10-22 19:27:05.822 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2020-10-22 19:27:05.822 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2020-10-22 19:27:05.823 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2020-10-22 19:27:05.839 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2020-10-22 19:27:05.841 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2020-10-22 19:27:05.848 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2020-10-22 19:27:05.848 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: Cannot render: found no usable devices.
    2020-10-22 19:27:05.848 Iray Render error: Invalid parameters (NULL pointer).
    Anyway, i love Filament (PBR)
  • yaggiland said:
    Hi,
    Part of log file :
    I suspect you need to update your drivers, though it's possible you have an older card which is no longer supported at all. Including the whole render section of the log for a simple scene, to keep it short, would have been more useful.
  • yaggiland said:
    Hi,
    Part of log file :
    Did you disable the 3dlight plugin if you did iray stopps working
  • yaggilandyaggiland Posts: 13
    edited October 2020
    yaggiland said:
    Hi,
    Part of log file :
    I didn't want to post the whole log, to avoid being yelled at by a too huge copy/past ^^
    I play with a 1080, and i have Nvidia Studio Driver 430.86 (Best time with Simulation dforce)
    Ok you are right, Another log part:
    2020-10-22 20:18:59.078 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : NVIDIA display driver version: 430.86
    2020-10-22 20:18:59.078 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.1   IRAY   rend warn : CUDA module initialization failed with error 'CUDA driver version is insufficient for CUDA runtime version' (0x23); iray photoreal can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com).
    2020-10-22 20:18:59.079 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : Using iray plugin version 5.1, build 334300.4226 n, 29 Sep 2020, nt-x86-64-vc14.
    2020-10-22 20:18:59.079 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.1   IRAY   rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
    2020-10-22 20:18:59.079 Iray [VERBOSE] - IRAY:RENDER ::   1.1   IRAY   rend stat : Environment cache size capacity: 5.
    2020-10-22 20:18:59.079 Iray [INFO] - BLEND:RENDER ::   1.1   BLEND  rend info : Plugin "blend render" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_cloud" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "irt_cloud" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "nitro_cloud" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iq_irt_cloud" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.079 Iray [INFO] - IRT:RENDER ::   1.1   IRT    rend info : Plugin "irt" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.080 Iray [INFO] - EIAXF:IO ::   1.1   EIAXF  io   info : Plugin "axf importer" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.080 Iray [INFO] - ICB:IO ::   1.1   ICB    io   info : Plugin "cb_importer" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.080 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_bridge_snapshot" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.080 Iray [INFO] - IRAY_CLOUD_SERVER:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_bridge_server" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.080 Iray [INFO] - EEMI:IO ::   1.1   EEMI   io   info : Plugin ".mi exporter" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.080 Iray [INFO] - EIMI:IO ::   1.1   EIMI   io   info : Plugin ".mi importer" (build 334300.4226, 29 Sep 2020) initialized
    2020-10-22 20:18:59.081 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
    2020-10-22 20:18:59.081 Iray [INFO] - IRT:RENDER ::   1.0   IRT    rend info : Resource assignment for host 0 has changed.
    2020-10-22 20:18:59.081 NVIDIA Iray GPUs:
    2020-10-22 20:18:59.081     GPU: 1 - GeForce GTX 1080
    2020-10-22 20:18:59.081     Memory Size: 7.9 GB
    2020-10-22 20:18:59.081     Clock Rate: -1 kHz
    2020-10-22 20:18:59.081     Multi Processor Count: -1
    2020-10-22 20:18:59.081     CUDA Device ID: -1
    2020-10-22 20:18:59.081     CUDA Compute Capability: NA
    2020-10-22 20:18:59.081     PCI Bus ID: 1
    2020-10-22 20:18:59.081     PCI Device ID: 0
    2020-10-22 20:18:59.081     TCC Mode: disabled
    2020-10-22 20:18:59.081     Display: attached
    2020-10-22 20:18:59.081 NVIDIA Iray Scheduling Configuration:
    2020-10-22 20:18:59.081     CPU Load Limit: 8
    2020-10-22 20:18:59.081     CPU Thread Affinity: disabled
    2020-10-22 20:18:59.081     GPU Load Limit: 1
    Post edited by yaggiland on
    edited October 2020
    Hun73r3dx said:
    yaggiland said:
    Hi,
    Part of log file :
    I have nothing disabled or deleted about 3delight, I never even use 3delight.
    yaggiland said:
    yaggiland said:
    Hi,
    Part of log file :
    "Iray [WARNING] - IRAY:RENDER ::   1.1   IRAY   rend warn : CUDA module initialization failed with error 'CUDA driver version is insufficient for CUDA runtime version' (0x23); iray photoreal can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com)."
  • yaggiland said:
    yaggiland said:
    Hi,
    Part of log file :
    Minimum driver requirement (on Windows) is 451.48
  • yaggiland said:
    yaggiland said:
    Hi,
    Part of log file :
    Ok, Thanks.
  • MEC4DMEC4D Posts: 5,249
    edited October 2020
    If you get error like that ( IRAY   rend error: Cannot render: found no usable devices.)
    there is 3 possibilities.
    1.your driver is outdated
    2. your card is not supported
    3. your card GPU is not selected
    nothing more nothing less
    But in your case I am sure your driver is outdated to work with the last build. I run with the same error in early builds but it was obvious that was old driver issue.
    yaggiland said:
    Hi,
    Part of log file :
    Post edited by MEC4D on
    yaggiland said:
    Hi,
    Part of log file :
    Problem solved on beta 4.12.2.54 (driver updated), thanks everyone.
  • dim_sh_ecd463260fdim_sh_ecd463260f Posts: 17
    edited October 2020
    In version 4.12.2.60 If I use a "Iray Section Plane Node", the Iray stops working. Black screen instead of render.
     Iray Section Plane Node works in the stable version, but not in the public build.
    I usually use the stable version, but this version doesn't support the new 3080 cards. Please fix this bug.
    I tried different drivers, different cards the result is always the same. It doesn't work in the public build, but it does in the stable version.
    Post edited by dim_sh_ecd463260f on
  • SevrinSevrin Posts: 6,313
    Someone else had this issue, but it might be a problem with the 30-series cards. It might affect some hairblending too.  Anyway, both work fine on my system with a 2080ti using today's beta.
    You might want to put in a ticket, because it's not a problem for everyone.
    edited October 2020
    Try using an Iray camera that takes only part of the scene for rendering. This camera uses Iray Section Plane Node. I tried on 1080ti  in the new build and the render didn't work for me. Everything works in a stable build. If you don't use Iray camera, the render works without bugs in the new build.
    I tested this on different computers and alternating between 1080ti and 3080 cards. On both computers, the render in the new build does not work well when using the  Iray Section Plane Node.
     I use Titan X and last drivers .
    working fine , check if the render engine is selected to Nvidia Iray and not Viewport under Render Settings engine
  • Is it supposed to be all white now?
    the interface is gone.
    3840 x 3300 - 1008K
  • barbultbarbult Posts: 26,518
    That usually means you installed it while it was running - a no-no.
  • amandainjapanamandainjapan Posts: 71
    edited October 2020
    now I know. >D how do i fix it, just reinstall it when it isn't running?
    Post edited by amandainjapan on
