Is there a way to create a separate object from a surface?
handel_035c4ce6
Is there a way to create a separate object from a surface (if it is daz matter - from a prop surface)?
Edit: I can export it to Blender, select the surface and then re-export it back to Daz in 2 batches, but can it be done in directly in Daz?
Post edited by handel_035c4ce6 on
Yes, use the Geometry Editor tool to select the other surfaces (easiest in the Tool Settings pane), or to select the one you want and then invert the selection (right-click menu), then right-click in the Viewport>Geometry Visibility>Hide Seelcted, then right-click in the Viewport>Geometry Editing>Delete Hidden. One done you fcan either export as OBJ/reimport or you can use file>Save As>Support Assets>Figure/Prop Asset.
Super useful, thanks!
