black Line
efron_24efron_24 Posts: 478
edited October 2020 in Daz Studio Discussion
For some reason at some renders there are black lines or spots on the face
that should NOT be there
Any idea what to do about that ?
Iray render  stopped after few minutes.. but even if i had done it to 100procent.. it would have been the same result (attached file)
Post edited by efron_24 on
  • nemesis10nemesis10 Posts: 3,865
    In the hair's parameter setting, adjust the haircap (in this case, adjust forehead) a tiny bit.  Iray is sensitive to bumpmaps and normals so if things are too close, you get an interaction.
  • setting the render settings instancing optimisation to speed instead of auto or memory often works as well without having to adjust the hair cap
  • If the figure is moved away from the centre of the stage (0,0,0), try moving it back - assuming that doesn't add problems elsewhere.
