I dont have scripts in tool bar
Hi i dont have label scrips in tool bar to do bridge with other software. Why? I downloaded and installed the bridge from site daz.
Tool bar or Menu bar? The Scripts menu is created when you add a custom action, by right-click on a content file, but you can also edit the menus in Window>Workspace>Customise (by right-click to add menus - menus tab on the right, Main Menus, and then by dragging commands across from the left). The bridges appear in the File menu - if you have the plug-ins installed and no commands try Window>Workspace>Update and Merge Menus.
Hi, i remember that when i installed the first bridge i had the script in menu bar. After i changed layout after i didn't show script in menu bar
i solved it, but it doesn't open c4d. The path of installation is correct?
hi, I cannot show up the Script Menu. Is the Script menu has to create mannually or is this automatically shown in the Daz interface? Thanks
