Converging to 100%
davidjones8418
in New Users
Probably missing something obvious here. But..
My renders are not stopping at the converged ratio, even with a <100% converged ratio selected and render quality enabled. They just sail onto 100%.
They are meant to stop, aren't they?
there is a difference between render progress and convergence %, the render will reach 100% when the image has reached whatever convergence percentage you have set.
100% where? The progress bar will go to 100% because it's measuring how close the render is to the target convergence ratio, not the actual convergence ratio.
Ah, okay.
I thought it was measuring convergence. Thanks.
