Moshi the Kitten - omg!
13»
  • memcneil70memcneil70 Posts: 6,110
    @ANGELREAPER1972 and @Joepingleton
    I popped in and my hair stood on end! Those three renders are Halloween. From totally scary terror, to trick or treat with a friend to the best witch-cat I have ever seen.
    Thanks for giving my season a great start.
    @Hypertaf, excellent work and I have enjoyed working with Moshi so much.
    Mary
  • HypertafHypertaf Posts: 134
    edited October 2020
    Mary
    Thank you, I'm happy to hear that! :)
    Post edited by Hypertaf on
  • thank you Mary/memcneil70
  • Hypertaf said:
    Thyranq said:
    Hypertaf said:
    Thank you all for the love to Moshi, I'm glad you like him! :)
    The pumpkin is my own model, so you won't find it on the store.
    Would you consider selling this pumpkin??  It really is perfect with Moshi!!!
    I would definitely buy the pumpkin
    Thank you, I'm glad you like it! :) Unfortunately, it's too late to submit Halloween products this year, but I might release it as a freebie if possible.
    That would be awesome!!  It's a great pumpkin!!!
  • XyetztXyetzt Posts: 27,549
    I could get one more thing with my stupid stimulus money.  I am debating between this cute cat or a kindle book I want.
  • Faeryl WomynFaeryl Womyn Posts: 3,779
    I'm having an issue with Moshi, it's not the vendors fault, it's probably my computer. I asked for help in tech help forum and one thing came up I never considered. Because I have an older computer and no nvidia card to render on, I have avoided going past Daz 4.10, however, in order to use Moshi I had to upgrade to the latest version of Daz. The only way I can get the other textures to work is through Iray, which my computer really really hates. I have the paid and free version of Iray to 3Delight and that is where I have a problem. In tech someone suggested if the fur is a separate item under surfaces, I could just use that to change the diffuse color...that didn't work, I have no idea what to change under the list in surfaces for the MTK Fur in order to get a black kitten. Can anyone give me some suggestions what I need to change to make Moshi black after using the Iray to 3Delight convterter?
    449 x 583 - 50K
     @Hypertaf, just a thought - if you were so inclined, you could do an add on texture pack for Moshi, with more coat colours, and maybe more poses, and then include the pumpkin in that product! I'd buy that!
    That would be great, the only problem is I don't have access to high-res images of other cat breeds. Without having image sets of all necessary angles for each breed, it would be very difficult to try to piece together a full coat from different sources.
    Hypertaf, I pm'ed you. :)
    Replied. :)
  • 3Diva3Diva Posts: 12,058
    edited October 2020
    I don't really know much about 3DL, but it looks like from the screencap that the fur is still using Blended Duel Lobe shader which I THINK only Iray can read. To change that to 3DL, you'd likely want to use the Iray Uber Shader on it first, then use one of your Iray to 3DL scripts on it. The scripts likely don't work on Blended Duel Lobe conversion to 3DL, since I think they were created before it was integrated into Daz Studio. So you'll want to change the Blended Duel Lobe to Iray first, then convert it to 3Delight.
    Post edited by 3Diva on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,565
    did you send pictures of your ...pussycat blush
    laughlaughlaughcheekydevil
    we get to play with your kitty?
  • more colours and poses especially expressions be great
