EXzella hair squiggles
in The Commons
I bought EXzella hair and was really bummed to see it render with hair squiggles. There are no morphs to fix this like we've all had to do many times with other hair. Someone posted that moving the render setting to HD fixed this, but that didn't work for me. Does anyone have an idea how to fix this to render without the squiggles? I hate to ask for a refund on a product that I otherwise like a lot.
I have read before that if you're uning an HDRI then turning off "draw dome" might fix the problem.
Scaling the hair up by a 0.5% or so should fix the problem.
Scaling up by 0.5% solved it. Thanks Leonides02!
Since you were able to solve the issue, I hope you don't mind if I ask which charater you're using the hair on?
Sure, it is Sasha and I applied freckles using Skin Builder 8.
https://www.daz3d.com/sasha-hd-for-genesis-8-female
